SELLERSRODSHOP
what is the best method to wire up an electric cooling fan into the ORIGINAL 69 wiring harness? i'm used to having dedicated circuits on new wiring harnesses & not sure what the best method is for grafting into the original harness to power the relay & adjustable temp switch. i'll also be adding a 3G alternator to the mix pretty soon for the added amps to power everything up.
