samsmustang
New Member
I used a GM style trunk latch solenoid from the junk yard ($5) on my 66. With little modification on the latches, it works perfect. I can even still use the key to open the trunk. The latch even has a switch built in so you can use it for alarm or a trunk light. I had to enlarge the hole on one side of latch on the trunk and cut and space out the body latch. I adjusted the body latch up and down to flush the trunk when closed. It's not an easy modification, but worth trying since I didn't have to cut or modify the car body itself, only the GM latches. I used all the existing bolt holes.
