Ok, wasn't sure if this belongs in the body section or the engine section but none the less, I have a question about the one piece export brace.
My buddy seems to think this should mount on the top of the lip that comes off of the cowl / firewall.
The problem is the export has a bend on each side and if you mount it the way he is talking about then the sides bend up instead of down. It just looks backwards to me. I thought it went under the lip of the cowl vent panel and the bent edges of the export should be bent down not up?
I could use a picture of a one piece export properly installed if anyone has one handy?
And by the way, here are a couple of pictures from the work going on this week.
Engine bay after paint....we were too lazy to remove the master cylinder before paint because we knew we were replacing it anyway.
Motor:
Motor:
