Engine Build
DougG69
I was asked to post the specs for my engine build on another forum, thought I'd throw them up here as well. Not that it's anything to write home about.
Quick copy & paste:
71 2-bolt main 351C block bored .030"
stock crank, rods shot-peened, magged & resized
TRW L2379F30 forged flat-tops
Comp Cams 282S Magnum camshaft, lifter & spring set
Scorpion roller rockers
Weiand X-celerator (will probably swap out for a Performer RPM)
750cfm vac. sec. Speed Demon carb
MSD 6AL & Blaster 2 coil
Ford Duraspark dizzy
Aussie 2V heads with 64cc chambers
2.19 / 1.71 Manley one-piece valves
Running through a TKO500 / McLeod hydro clutch setup. Still running the factory 3.00 peg-leg, will be upgrading to a TrueTrac / 31-spline / 3.50 setup next spring.
Exhaust is FPA headers, a 3" Dr. Gas X-pipe, Spin-tech Sportsman Streets, and Flo-Master 2-1/2" tailpipes exiting under the rear valance.
I would also like to see what others are running, mild to wild, if you feel like sharing :beer
I'll bite...
357 cid
69 351w block bored .030" over
stock crank
Eagle SIR forged I-beam rods
Probe SRS flat top forged pistons
11 to 1 compression
Clevite H-series bearings
Total Seal moly rings
FTI custom solid roller camshaft (.640"ish lift with 1.72 rocker arms; 230ish duration @ .050")
Ported Canfield 192 cylinder heads (308cfm/258cfm @ .700")
Scorpion 1.72 full roller rockers
Jomar stud girdles
Comp cams valve springs, retainers, locks
Trick Flow .080" pushrods
Vic Jr. intake manifold
Barry Grant Mighty Demon 850 annular booster carb
Hooker Super Comp headers (1.75" x 3")
3" exhaust w/ Hooker Max Flow mufflers
Ed Curtis from FTI said the engine should make 415 rwhp through an AODE transmission. That puts it around 530hp-540hp at the crank.
@ 6T9mach1 - Ryan, sounds killer to me!
@ monkeystash - I just threw a quick clip up on YouTube this morning (first time I've tried to record video with my digital camera). At least you can get an idea of the sound ;)
http://www.youtube.com/watch?v=2JZwdmGisjU
I'll have to figure out how to embed video sometime.
I'll bite too
My 66 Coupe Specs:
68MY 302 2V
.030 overbore
10/10 Crank
Stock 63 cc heads with pressed in studs and thermactor bumps
Melling OEM style rail rockers
Melling HV Oil Pump
Comp Cams 260H camshaft
Edelbrock Performer Intake
Edelbrock 600 carb
NAPA reman distributor with pertronix conversion
Factory Exhaust Manifolds
Ebay $159 2" wrinkle bend dual exhaust
recurved distributor I believe 36
All the old farts here have seen this, but I'll post again. These are the specs it will be when I get it back together. Roughly the same as before except a rocker change.
66 289 C code (the original A code was toast when I took it apart)
.030 over
Stock Crank
Eagle H beam rods, SRP alum pistons with low tension rings
Stock 66 iron heads, ported to the gills. 1.84 intake and 1.5" exhaust (genuine GT40 valves)
PRW 1.6 shaft mount roller rockers
Center oiling solid lifters, hardened push rods
Beehive valve springs
Melling HV Oil Pump
Canton 9 qt road race pan
Elgin custom grind solid lifter cam, .347" lift, duration 284, lobe sep 106 degrees with 36 degrees overlap
Edelbrock Performer RPM Airgap Intake
Holley 650 DP carb
MSD 6AL box (7,200 chip) and Blaster coil, factory distrib.
Ceramic coated Tri-Y's, X pipe, 2 1/2" side exhaust with Dynomax race bullets
SFI alum flywheel
SFI Dampner
Alum water pump
Last time on the chassis dyno (09) it pulled 313 HP and 295 TQ
Now, if I can just get it back together before the track days start back up [nb]so I can break it again[/nb]
I'm in the middle of my engine build as I write. I've got the short block about 90% done:
331 Stroker
Roller block
Scat 9000 crank
Scat 4340 forged I beam rods
Probe SRS flat top pistons, running a little over 10:1 CR
Trick Flow FAC 170 heads 2.02/1.6
Trick Flow 1.6 roller rocker arms
Trick Flow stage 2 cam: Duration @ 050 lift: 224 int./232 exh. Lift with factory rockers: 0.542 int./0.563 exh. Lobe separation: 112
Melling oil pump
Canton 9qt road racing oil pan
Holley Systemax II intake
30 lbs injectors
75mm Accufab throttle body
90mm MAF
JBA stainless shorty headers
2-1/2" exhaust
5sp t5-z transmission
9" diff with TrueTrac/3.89 gears
-Shannon
