I am building up a 408W stroker and need a some advise on parts to complete the build. I have a 94-97 roller block that cleaned up at .030 over and ordered an Eagle forged rotating assembly
http://www.eaglerod.com/mosmodule/productsearch.php?dowhat=assy&searchbyno=14125
Going with AFR 205 heads, likely an airgap or Weiand Stealth intake. Running a T5 with 3:73 rear gears.
So what cam will best fit this combo? I just want to build a strong street motor and maybe see 1/4 mile pass every now and then. I would like to see 400-450 at the crank (just for bragging rights) but I don't really have a set HP number to achieve. I do have a 4100 carb (1.08 venturi) that I may rebuild and use but that is still up in the air.
So hit me with your cam recommendations and even what flywheel, intake, carb for this build. Help me spend my money :thu
