ok got a 67 mustang with a 351w auto fired it up hell of a deep knocking noise oil pressure is 60 psi cold oil is clean looks like quite a fresh engine.
So i took the motor out thinking im going to have to get the crank done .
the flexplate was loose could physically moved it by hand can this cause a heavy knocking noise when engine is running? reason i ask is before i start stripping the motor down im thinking this might be the problem any thoughts anyone :beer
