68angrypony
As my restoration has evolved to more money and cost, I find myself having to pull the motor back out to paint the engine bay. Since the clutch hasn't been engaging anyways, it will allow me to investigate the issue. I am considering swapping transmissions and I wanted some recommendations on what my options are. Right now I have a 351c attached to the 4 speed t-10 transmission that was attached to the 289 i pulled out of the car. Here are some bullet point facts:
1. Have only rolled through the gears on the trans with the car parked. Never driven on the current trans but I am assuming its in working order
2. Motor was used when I purchased it and has an edelbrock intake and carb. Past that, I have no idea whats been done on the inside of the motor. Sounds pretty healthy though
3. motor is coming out and it seems this would be a great time to upgrade from what i have that should work to something that would be a more permanent unit so I can have a final location for a shifter to possible build a custom console around it or use a factory one if I can get it to fit.
I would love a 6 speed, but would be ok with a 5 speed. What would be my best bet to go with? What type of fabrication would be needed with what? Would any 5 or 6 speeds work with the bell housing I have now? Any factory transmissions I can look to get my hands on like a corvette trans etc?
