Fst Blk
If you plan to do bc/cc later, do you need to use a 2-stage epoxy primer or is a single stage ok?
Bill
Bill
"67 Fastback" said:But then I started noticing alot of guys like the Kirker brand epoxy for it's sandability.
"buckeyedemon" said:why the need to have good sandability in the epoxy?
if you need to scuff it, get some red scotch brite pads.
Listen to this advice it comes out like concrete if you dont reduce, and your sanding/wet sanding will be a PITA. I also like to spray self etch primer on bare steel then prime/guidecoat/wetsand-SEM makes a good product but it is $$$. I just Switched to Meguire's-Black Magic Paper and i Do not like it Goin back to 3M micro fiber."stangg" said:just before base coat I sprayed a coat of the 2K urethane prime that was reduced 10 or 20 percent to help it flow a bit smoother. That seemed to work well for me...
