Evaluating carb Through Plugs
Sacbill
Hard Swinger
I'm trying out some different jets in the carb and want to make sure the motor's not running lean or rich by checking the plugs.
I was going to start with new plugs as a clean baseline... should I run the car for about 30 minutes before checking the plugs (enough running time)?
Tapayakkin' from Sacramento ....
you really need a stretch of road where you can get on it, shut her down and coast to a stop, then pull the plugs.
As said.....any idling will most likely show as rich/black on the plugs. You need to run the car long enough for proper temps to be reached, run it at a fairly steady speed, and shut the key off and stop. Then you can pull a few plugs on the side of the road and decide what to do...
