68stang289
I'm still trying to fully sort out my drivetrain that was kind of mashed together in my 70 by the previous owner. It's a 70 Mach with a 428 SCJ and a 4 speed toploader. The toploader in the car is a HEH-BW (66 Mustang 289, wide, 28-spline). I believe what is correct for the car should be a RUG-AZ (70 Mustang 428CJ/SCJ, close, 31-spline). The clutch fork however is a different style than what the 70 428 cars would have come from the factory with (there is no hole through the clutch fork for the lower clutch rod to fit through). Instead it has the dimple style like you would find on a 66 289 4 speed car. I didn't have the opportunity to look for any numbers or anything on the clutch fork before it was reinstalled in the car because my dad went ahead with the install without me so I don't know off hand what the numbers are. Here are my questions:
1. Is there going to be a difference in size (length wise) or a different pivot angle using this unknown clutch fork? What are the potential problems associated with a wrongly paired clutch fork?
2. Would a small block (figure a 351 since that's what the car was before the 428 was transplanted) clutch fork theoretically fit the FE bellhousing?
3. Is it possible to swap a big input shaft into a small input shaft toploader? Any potential issues with doing that other than needing to switch out the pilot bushing? Would I also need to switch out the tailshaft?
Please forgive the ignorance of any of my questions. This car has just been a giant cluster of mashed together parts and sorting out the right way to get stuff done has been a giant headache :hs
