I am having no luck finding info on the pros and cons on a flat tappet cam vs retrofitting my C9 351w block. I have a set of afr 205 heads and I'm ordering a 418 scat stroker kit. compression should be about 10.6 with 22cc dish pistons.
I'm also torn between an rpm airgap intake and a vic jr.
trans is a TKO600 and rear end will be 3.50ish geared. I've talked to the engine builder and he didn't seem to have much preference either way on the cams and he was leaning towards the air gap intake.
