68stang289
I have been reading up on installing the back glass (and possibly the front glass as well) on my 70 fastback myself but had a few questions for those of you have done this yourself.
Back Glass:
I have read two different schools of thought on the install - one using a 1/4" rope inside the seal and one using a plastic spatula like tool to slide the window under the seal. For anyone who has done this, which way was easier? I tend to think the non-Ford manual way and using the plastic spatula type tool would be the easier of the two.
I have also read two different thoughts on using the sealant. I have heard the repop seals are very prone to leaking and that I should pipe the sealant into the outer lip of the seal before placing it on the car. Then put the rear glass on and work it around into place and follow that by piping in sealant to the inner lip of the seal. Some people say to use a bunch, some say that a little dab will do ya. Anyone with experience in this car to chime in about it?
As far as getting the rear trim to pop into place with little damage, any tips or tricks for that?
Front Glass:
I seem to recall there being two small pieces that attached to the A pillar with screws and they had little rubber insulators on them but can't seem to find those. Are they reproduced and are there only 2 (one per side)?
Difficulty level of installing the front glass for someone who has never installed glass before (and only seen it done once before)?
Back Glass:
Front Glass:
