AtlantaSteve
John,
First off, I know this is your sponsor forum, but I'm hoping you can give me some help, based on a comment I saw you once make on another forum that I have been thinking about ever since you said it.
On this other forum, you mentioned that there was no reason, that someone couldn't make a pack of Leaf Springs like the biased Maier Racing springs out of standard springs.
I have a set of stock leafs on my car, and a set of aftermarket 4.5 leaf reverse eye dropped springs on my shelf.
If I get the measurements of a set of maier springs, and use my angle grinder with cutoff wheels, do I have everything I need to do it? I'd basically just take the pack apart, cut all the leafs to the right size to match the maier pattern, and put the pack back together right?
Has anyone ever done this? If so, do you know the performance results?
Monkeystash has a set and is going to get me the measurements, that should be enough, right?
Thanks for any advice or guidance you can offer
Steve
Steve
