FS: 70 Convertible Parts Extension Visors (in NY)
Fordrevhead
New Member
OEM 1970 Mustang Convertible ONLY Drivers side LH Rear Quarter Extension.
This will not fit a coupe or a fastback.
Very good original condition, original paint only one notable scrape seen on the lower corner of the outer edge on the first picture. Even this appears like it might almost completely disappear with just sanding and primer surfacer.These are rarer than Shelby's! Very difficult to find and they are not made aftermarket!
Pair of OEM Black Rear Interior Quarter Trim
1969 or 1970 convertible only
These are complete with the screw on stamped metal area where the quarter window, window seal and handles go and the rest is molded abs plastic (no cracks) covered with vinyl. These have both carboard backers and both of the ashtrays intact as well. Ready for reconditioning.
FOMOCO #'s:
C9ZB-7631112 RH &
C9ZB-7631113 LH
Underneath those numbers they both have N.A.P. 69-12 So December 69 is the date code.
1969 1970 Mustang/Cougar Convertible Sun Visors & Brackets
Fit a 1969 or 1970 Ford Mustang or Mercury Cougar Convertible ONLY
Part Numbers: C9ZB-7604122-D 37792 and 37793
Visors themselves are Black and usable but they are old and dirty and there is a small thru- edge wear spot on one of them.
These are both the left and right hand cast parts that the visors swing from and the convertible top latch to. These brackets are in good, original condition. There are not any cracks, missing tabs or oversized mounting holes. There is pitting as shown on the cast brackets. There is some wear in the location where the Convertible top latches on but even worn latches still held fine on these and this could be filled if desired during reconditioning. There is some moderate surface rust on the visor stem and the tension spring. Visors themselves are Black and usable but they are old and dirty and there is an edge wear spot on one of them. The original visor tips are in tact as well but again would be replaced during restoration.
The mounting screws are not included.
Original Ford Mustang Convertible sun visor brackets are difficult to find and reproductions are not available. Use these brackets to complete your classic Mustang restoration.
don't suppose you still have these?
FOMOCO #'s:
C9ZB-7631112 RH &
C9ZB-7631113 LH
