I have a situation where I'm wiring up a fan controller that is rated at 50a and uses a 10ga power wire with a 14ga fusible link. The problem is the controller is mounted right next to the distribution block, so I don't need a very long supply wire. Does anyone know of a minimum wire length for the fusible link? I'm probably looking at 6" total wire length and was thinking 3" of power wire and 3" of fusible length. I'm tempted to not even use a fusible link due to the short wire length, but then the system isn't fused. I know the theory behind the fusible link, but don't understand how the length of wire comes into play when it comes to the wire heating up.
