Gary's '66 conv.
New Member
Am now looking at installing a 1990 5.0 with EFI in my 1966 conv. Anybody had any experience doing this and will it fit under the stock hood?
I am also using a TCI front suspension which reqiures a rear sump oil pan. And going to use the AOD tranny thats hooked to the motor. Planning on putting a Vintage air front runner system on it also.
Ken when you say the 5.0 accessory kit wouldn't fit what are you talking about? Did any of you guys do anything to the engine to boost the horsepower to around 300?
Because of that specially calibrated ass-o-meter you carry around?...I know it is putting more than 300 hp to the wheels.
Based on the equipment installed and the info supplied by the tuner, the engine should be in the 400hp range, assuming a very generous 25% drive line loss.....300hp seems like a very safe number to bet on. Now most will call out a 15% drive line loss...but again, being the generous, giving guy I am....I pushed it to 25%.Because of that specially calibrated ass-o-meter you carry around?
I've kept mine bone stock, primarily due to it's intended use. With that said, even in stock form the 5.0 will provide a good kick when dropping it into a '66. The power to weight ratio is better due to a '66 weighing a little over 700lbs LESS than a '92!Did any of you guys do anything to the engine to boost the horsepower to around 300?
Ken, did you use stock spindles or the 2 inch dropped spindles? Also what size tires did you go with?We put a 1993 style cobra EFI set up in our 65. It cleared the stock hood by 1/4" in the tightest spot. That being said, I do not have the shock towers or standard engine mounts as we went with a TCI front end. I do know many others were able to make it fit with the standard setup. Most likely you will not be able to use the spacer between the upper and lower manifolds, such as is common with the 5.0 crowd. I can send some pictures if you would like.
Ken
