What have you guys done for running power to the doors for central locking? On the passenger side there is a hole in the end of the door and another on the outside of the upper kick panel which i am guessing is for a loom?
There are no holes on the driver side door/kick panel. time to get the drill out?
I was thinking about getting some of the rubber flexible wiring sleeves that most modern cars use. BMW to a nice one. Something like these
Then i am using a single wire alternator with internal regulator and have relocated my battery to the boot. I have run two heavy gauge main cables from the boot. Where do i go from here to connect to my harness. Iis there a main terminal/fuse i need to go to before going to the loom?
And finally the gearbox connections(Speedo, neutral safety). Where is the best way to route the cables. Just drill a hole and go through the firewall and down along the inside of the tunnel?
