Granada Swap - Outer Tie Rods
dm289
Quick question, when doing the granada swap on a 66 which outer tie rods are better to use Granada or 70 mustang??? I believe both will work but one may require trimming to fit, does anybody know for sure???
Thanks,
Dan
the Granada requires a different taper than the 66 Mustang so the 66 tie rods will not work. I honestly don't recall when the Mustang taper changed so I'm not sure if the 70 will work. When I did the swap on my 67 I used Granada outer tie rods.
There is also some issues with the Granada spindles on pre-67 because of the geometry changes. Contact BobV for the details as he has some horror stories to tell when he did the swap.
I believe NPD or Mustangplus has parts for the granada setup so they must have the tie rods also.
:confu
There is a slight variation in the 70 tie rods compared to the granadas. They will work but recommend using the granada tie rods.
