"70_Fastback" said:But for what he is wanting to grind out, most of the disks are too large. I would recommend using a standard 4-1/2" cut off disk. The same one you were using to your steel.
I use those a LOT for grinding down humps and recutting a line - such as you are wanting to do. Use the edge of the cut off disk to basically slice through your welded seam to re-expose that existing joint. Then use the same cutoff wheel in a sweeping type motion to take the remaining ridge down. You don't have to remove exvery bit of it, but try to remove most of it.
Just go easy with it on the sweeping motion, not a lot of presure - just let the disc do the cutting through and hold a very steady hand.
"Ponyman66" said:A word of caution with them; use gloves, long sleeves, goggles AND face shield. Also blow away grinding debris from yourself frequently. The burr produces very small slivers as it cuts, which get EVERYWHERE! I had a weld in a very enclosed area that I couldn't get any of my grinding disks into. The first time I used the burr I didn't have long sleeves. I then took my gloves off and brushed of what I initially thought was metal dust. Stupid me! After digging VERY annoying metal slivers out of my hands for the next week I learned! Duhhhhhh! :roll
"Opentracker" said:![]()
I will have some of these with me on Sunday when I come up. They go on the 4 1/2" grinder and are by far the best grinding tool I have ever used. You can see your work as it's being done.
Here is a page where you can take a look but I get mine from Fastenal.
http://www.nortonindustrial.com/DCWheel ... -FLEX.aspx
