68stang289
I'm finally at the point to start considering exhausts for my 70 428. The car is a 4 speed car so space is TIGHT up on the driver's side manifold. What I'm debating is between going with a 2 1/4 or 2 1/2 exhaust. The 428 is pretty built - TRW .060 with big valve cuts, Crower solid cam, ported intake, Lemans rods polished with ARP bolts, windage tray, Ford power Parts rockers, stands, spacers and pushrods, shell lifters, steel roller timing with all machine work. The car had full length hedman headers on it, but I have switched back to stock aftermarket exhaust manifolds. I'm concerned that there will be too much back pressure going with the 2 1/4 with the manifolds and that the 2 1/2 will not fit properly due to the added 1/4". Thoughts?
