Help! Dash Lights Questions
MarkStang
My dash lights stopped working as well as the indicator for the shifter. Fuse is fine but when I check voltage with fuse in both sides are nill , like .4 volt and when I dim the switch it goes to .1 volts. Without the fuse in hot side is full voltsge. The dimmer control has been shorting. I have had to fug to get dash lights. I can not remember if the shifter light is tied into this.
Is my light switch the cause?
If one lamp is out will all be out, I can not remember.
I am actually hoping it is the dimmer.
I have always had this dimmer issue and worked around it , The only thing I did recently was put in a speedo cable. Could it be a dash ground? I seem to remember that the dash lights worked with the bezel flopped out.
Thanks for your help.
I believe the shifter light is separate from the dash lights as in it is on when the key is on.
Yes, it could be a dimmer problem. Move it around and twist it a see if you get a bit of light.
Lamps burn out individually UNLESS the problem is main power to them or a bad ground.
Did they get knocked out of the sockets when you removed the dash?
Hmm where is the ground for the dash light?
I checked all bulbs 18 times, argh.
I suppose it could be the dimmer switch. I remember a ground or plug under the AC unit I can check for the shifter.
Thanks for the help so far.
On the '65/'66, there's a separate ground strap for some of the indicators. It's not part of the main harness.
One of the indicator LED light has a ground strap. I just saw that NPD has a repo switch for only 14 dollars. So if fresh eyes can not fix it tomorrow I will go for the new switch. I did some searching on the net and found that the repro is cheap but seems to work just fine.
Thank you for your help again. I will update the resulting fix.
Fixed with a new headlight switch. The cheap 14 dollar repro. The grounding strap was not needed. The shift bezel was tied into the same switch.
