1965Mustang
A few clarifications to get rid of the obvious. I know the firing order for a 93 HO roller and a standard roller are different. The cam and crank marks were lined up as they should be. I have a Comp Xtreme cam. Called Comp and was told could not be the cam and would only go in one way. The harmonic balancer is the one that came off the engine and can only be put on one way. Crank is same crank. New Trickflow heads. When the #1 and #6 pistons are at TDC the timing shows off 180 degrees. Yet when #5 piston is TDC, the timing is where it should be. I am baffled unless the valves are adjusted wrong. New MSD distributor appears to be lined up correctly. Someone tell me what I am missing or how stupid I am being if you have the correct answer. I'll take the ribbing to hear this thing run! Thanks,
