gt289
Car is a '68 coupe I've had since new. Problem is fairly recent- no more than 5-6 years.
I've got the battery on a master switch, otherwise it would be dead in a week or so.
Out of boredom, I decided to delve into the problem yesterday.
Alternator rebuilt (not reman) a few years ago and there's an electronic voltage regulator.
Putting a test light in series between the battery's positive terminal and the cable doesn't
illuminate the light. If you open a door it does, but it's dim.
I took a reading yesterday, when I unplugged the regulator. It was 12.34 volts. This morning
it shows 12.26 volts. Probably 10 hours have passed by. I'm guessing the alternator or
voltage regulator probably aren't the problem.
I've got both a digital voltmeter and an analog one.
Anybody got any ideas? If I have to pull fuses, one at a time, this could take awhile......
