Daves69Coupe
How much black epoxy primer would I need to paint my entire car?
"mustangstofear" said:Are you just wanting to cover the outside If you are a gal might get you buy. If you have bodywork to block sand you will need a lot more. I don't know of any direct to metal primers that I would respray the next day without sanding the primer before hand. Rich.
"Midlife" said:You might be right, and maybe I confused a top coat with a second coat of primer.
"SELLERSRODSHOP" said:with the DP series of epoxy mixed as a sealer, the tech sheets say you can shoot topcoat in a few hours without scuffing,
"buckeyedemon" said:where does the tech sheet state this? i will in many times wait a day after spraying the dp before applying my fill primer (i haven't been scuffing and my garage never sees anything above 90F) (maybe you are referring to actual color coats only?). i certainly don't want to be doing something the wrong way.
https://buyat.ppg.com/refinishProductCatalog/ViewProduct.aspx?ProductID=ebd75e7f-7489-4334-a387-73f8653e2a34
"buckeyedemon" said:thanks for the compliments. do you know of a guy in the Galatin area named Paul Herman who has his own shop?
