sigtauenus
I was working on my motorhome for some friends to borrow, and while I had it apart to do some work on the freshwater water pump, which is located under a seat, I noticed that the seat belts were attached to a metal bracket which was about 3/8" diameter and that that bracket was screwed to the wood frame of the seat.
How cow Batman, seatbelts attached to wood in a vehicle?
This issue comes up again because in the past I've asked and read several discussions regarding seatbelts and child seats in the back of our cars. Most discussions involve welding or bolting heavy duty brackets to attach the seat belts and/or straps.
Do we as a group over engineer safety? (as if that's possible)
I'm not a mechanical engineer, so I'm wondering how you go about determining what size bracket would work ok for a child seat strap (like for using the newer LATCH system), or what means would be sufficient (bolt/washer sizes - welding) to attach that bracket to the floor/frame of the car.
