how to grease upper control arm ball joint
How do you grease the upper control arms ball joints? I see their is a lil nipple with a ball inside, but I don't know what I would use to got grease in there. Is their any way to clean out the grease those ball joints and get them packed with new grease?
"cmayna" said:
Grease gun?
Yes!!!
That lil nipple is a check valve fitting. Your grease gun will "plug" into that fitting and you can pump grease in until the old grease squirts out of the rubber boot area.
