Huge lot of 67/68 suspension and fastback parts for sale
1967marti
I'm selling my entire lot of parts off a 67 fastback...
Message me or ask for pictures *trying to be nice to the low bandwidth guys and gals)...
1. L & R Shock tower cap w/bumpers (dynacorn, new) 70$
2. L & R Global West adjustable struts Bolted to car but never driven) 300$
3. L & R Global West Lower Tube Control Arm W/ ball joint (bolted to car but never driven) 300$
4. L & R Global West Upper Tube Control Arms w/ new ball joint (bolted to car but never driven) 400$
5. Metal template for “Shelby drop” 10$ or I’ll add for free is you are buying something else
6. L & R front spindles, 1970 date, w/ new bearings (cleaned and painted) 200$
7. L & R Front Brake Calipers (4 piston type, Ford, New from store) 200$
8. Complete Working 67/68 Instrument Cluster (OEM with new body, lens, 2 speed wiper switch, and wire harness) 250$
9. Dash trim kit (new, non oem, 3 piece) 30$
10. Grab A Track 5 leaf, reverse eye leaf springs (bolted to car but never ran) 180$
11. Ron Morris rear leaf spring plate set (mounted but never ran) 100$
12. 67-68 1 1/8 front sway bar with grease-zerk mounts w/ links (mounted but never ran) 80$
13. Roller spring perches (mounted but never ran, from mustangunlimited) 200$
14. Black 3 point seat belts ( one pair) 100$
15. Russell dual carb fuel line kit (model# 641183, new in package) 80$
16. Russell (I think) Carb fuel like kit 3/8 fitting size (looks like # 641165 but without shrink tube on flex hose) 40$
17. Pair of oem under-dash vents 20$
18. 1967 rear view mirror assy (looks too ‘new’ to be OEM and I see no fomoco stamp) 15$
19. Pedal Assy w/ roller bearing kit installed (manual) 200$
20. OEM Mustang standard 20 inch radiator shroud. (Has C9ZE-8146-C stamping ) 50$
21. OEM 1968 trunk hinge (pair) 60$
22. 67 OEM Hand break (broken plastic handle, easy fix) 20$
23. 67 OEM ashtray assy (both inner w/ lighter socket and outer door) 15$
24. LH Fresh Air Vent W/ cable, bracket, and knob (rubber still like new) 50$
25. OEM Fastback Quarter Vent trim panel L & R (In perfect condition 4 pieces in total) 150$
26. OEM Interior Vent Grilles (pair, in great condition) 80$
27. OEM Interior fiberglass side panels (pair, in “good” shape) 200$
28. OEM Interior fiberglass sail panels (pair in “ very good” condition) 60$
29. OEM Black fiberglass quarter vent door “bucket” (pair “very good” condition 100$
30. OEM Fastback fiberglass fold down rear seat window trim 40$
31. OEM L & R fiberglass rounded interior sections
(trap door side panels) 50$
32. OEM L & R vent diffuser (pair) 40$
33. 351 Cleveland timing chain cover plate (has some pitting under water pump area but otherwise great shape) 40$
34. Ball joints for Global West lower control arm (pair, new in box #FA395) 20$
35. 2X sets of bearings for 1970 spindles (2x SET12 and 2x SET13, new in box 4 pieces total) 30$
36. Bracket that holds steering column to underside of dash 5$
37. Pair of metal plates of latches (go on interior fiberglass quarters) 5$
38. New brake hoses for front disk brakes (mentioned above) 20$
39. Metal molding for fastback interior quarters (below the vents) 40$
Here are a few quick pictures... This was a Kit from mustangsunlimited, I have the floor bolts and washers to go with it, but the bolt near the ceiling depends on your anchor. The kit was 199 + shipping.....
I added two pics of the little plastic nub that got broke off (one on both re-tractors) it's an easy fix or you can just take off the guide entirely... I figure 100$ off is pretty fair for a 10 minute fix... Let me know if you want some more pics...
Here is the updated list, sorry I haven’t done it sooner but with turkey day and all the emails and calls it’s been crazy…
1. L & R front spindles, 1970 date, w/ new bearings (cleaned and painted) 200$ OBO
2. Complete Working 67/68 Instrument Cluster (OEM with new body, lens, 2 speed wiper switch, and wire harness) 200$ OBO
3. Dash trim kit (new, non oem, 3 piece) 30$ OBO
4. Grab A Track 5 leaf, reverse eye leaf springs (bolted to car but never ran) 180$ OBO
5. 67-68 1 1/8 front sway bar with grease-zerk mounts w/ links (mounted but never ran) 80$ OBO
6. Black 3 point seat belts ( one pair) 100$ OBO
7. Russell dual carb fuel line kit (model# 641183, new in package) 80$ OBO
8. Russell (I think) Carb fuel like kit 3/8 fitting size (looks like # 641165 but without shrink tube on flex hose) 40$ OBO
9. Pair of oem under-dash vents 20$ OBO
10. OEM Mustang standard 20 inch radiator shroud. (Has C9ZE-8146-C stamping ) 50$ OBO
11. OEM 1968 trunk hinge (pair) 60$ OBO
12. LH Fresh Air Vent W/ cable, bracket, and knob (rubber still like new) 50$ OBO
13. OEM Fastback Quarter Vent trim panel L & R (In perfect condition 4 pieces in total) 150$ OBO
14. OEM Black fiberglass quarter vent door “bucket” (pair “very good” condition 100$ OBO
15. OEM L & R vent diffuser (pair) 40$ OBO
16. 351 Cleveland timing chain cover plate (has some pitting under water pump area but otherwise great shape) 40$ OBO
17. 2X sets of bearings for 1970 spindles (2x SET12 and 2x SET13, new in box 4 pieces total) 30$ OBO
18. New brake hoses for stock 4 piston front disk brakes) 20$ OBO
