I know just enough on the subject to be dangerous. I'm seriously considering buying an engine that uses a set of hypereutectic pistons from Eagle. Final compression ratio is just a tad over 10:1. Cast crank with 5140 I-beam rods (both again from Eagle).
I'm looking to hear from those who really understand the differences (good and bad) of piston construction to give me opinion here. Or those who have/had an engine with such and can comment from that experience.
I think at about 425 h.p. all is good and no concerns but I also am pretty sure any type of power adder is going to be way to much given the current CR and piston construction. Engine has aluminum heads which should help with detonation concerns a bit.
Thoughts?
Thoughts?
