AzPete
I need the length, diameter, and thread of the following bolts from a stock 289/non A/C setup.
1. The pivot bolt that goes into the head for the alternator.
I also need the size of the spacer used here.
2. The bolt that attaches the alternator slide bracket to the water pump.
3. The lower bolt for the upper alternator bracket. It also mounts into the water pump.
Reason, I need to buy them locally so I can convert mine back to a V-belt. I will have to make some spacers to line up the two bolts going into the water pump.
