67resto-coupe
so i was reading an old article in car craft (jan.'09) on a new boss 302 crate motor. most of their motor specs were pretty close to what i have....main differences were heads and carb. they're running turbo swirl alum heads and i have iron gt40p heads. the tester boss also has a 650 holley w/mech secondaries, jetted at 69/75...i have a 625 demon w/vac secondaries, jetted at 67/72.
from there, i read that they ran 37 degrees of total timing. seems like a lot. i'm running 16 deg initial and have the 18 degree black cent.advance stop bushing on my msd billet dizzy. so that should put me near 34 degrees of total timing, right?
QUESTION: is there a maximum amount of initial timing that you can run? can anyone tell me what bushing they're running in their msd? the instructions indicate that i can swap out the 18 degree BLACK bushing and swap it for a 21 degree BLUE bushing. that would get me to 37 total = 16 init + 21 degree cent.adv.
is there power left in those extra 3 degrees that i haven't tapped into? can i pull the bushing without pulling the dizzy? i hate to have to do that....should i swap the bushing?
thanks in advance.
thanks in advance.
