Inline PDF files
Sluggo
[pdf]http://www.stangfix.com/images/sum-m08040-41.pdf[/pdf]
[pdf]http://www.stangfix.com/images/camchoice.pdf[/pdf]
Interesting. Are there any parameters to make the width fit the screen better? (A bit wider?) Nice feature! :thu
I can likely change the code to allow wider. It could have a negative affect on those running lower resolutions though. It's 500 wide already.
If you save or print it you will get the full file.
Very nice. I can see lots of use for this one. FWIW, I'd leave it at the 500, those that need the higher detail will likely save it for future reference anyway.
Agreed. It's a pretty simple change if it becomes necessary.
