oateater
Here is my problem on a 66 mustang conv. When I open either door with ignition key off under dash and rear console lights work normal. Open door, lights on, close door lights off. With key in assy position or engie running rear console light comes on with doors closed. Open a door and rear console light goes out and under dash lights come on. Arrrrg!
History. Installed console and ralley pack about a year ago. Have never noticed this before I can't believe it was that way when I installed this stuff as I check things pretty close when done. I have recently had the dash gages out a couple of times for a new gas gage [which still does not work properaly] and a speedometer cable.
Any thoughts where to start? I haven't hooked anything to the ignition switch. all hook ups where plugged into the main wire harness.
