I'm going to dive into the exhaust/headers change over tomorrow morning. I finally got my mig welding tank filled. The last time I got gas it was $16...now it's about $35. My how things go up in 15 years...lol. I got shorty cermaic coated headers because I have an aod tranny and it is hard to fit anything with that darn thing. I'm going to do like some one else did on here and run it out just in front of the rear tires. My old exhaust is leaking and I have welded it up so many times because it keeps dragging the old glass packs off going over really high speed bumps or driveways that have a big dip. I am getting ready to do the efi swap also, so I need to be sure the headers fit ok before drilling for the O2 sensors. My question is: how do you drill through the ceramic coating? I am wondering if a special bit is needed. I have some step bits I used a long time ago to install the bungs for O2 sensors. I tried the efi before (couldn't get it to work). I had the car down for 6 or 7 months when I went through the '90 engine and aod to put in the '66. I forgot (it had been so long) that I had a kill switch under the dash and that is why it wouldn't work when I started and started it. I got disgusted and snatched it off and put my professional products shiny intake/edelbrock on to try out the new engine/tranny. That's how it has run the last 8 or 9 years. I got the clamps that are like a sleeve to fit over the ends and can be removed, if I have to do any work where the pipes have to come off. I'm wondering if I need to tack the pipes together before using the sleeve clamps? Also got the dynomax turbo mufflers that have the valve inside. 2 1/2 all the way. I'm gonna get 'er done...I hope. :roul
