Late model transmission question
Stokes66
What the newest year that will work with my 66 302. I read that 84 is when the motors became efi but I can't find when the trans became computer operated. I've found a few trans but I don't know if they'll work.
Thanks
Sent via paper airplane.
You preferably would like to get an 88 or 89-93 AOD from a V-8 car as they (the V-8 car transmision) has more clutch packs and is stronger, I think the T-bird supercoupes transmissions also had more clutches like the V-8 cars. Pre 89 or 88 had tailshaft oiling issues. AOD-E's are just that electronic controlled and require the factory wiring and computer or a stand alone controller such as offered by Baumann transmissions. http://www.becontrols.com/ Hope this helps and answers some of your questions.
Yes sir thanks a bunch
Found a transmission guy in memphis that rebuilds and installs AODs for what I think is reasonable. He said trading in my old 3 speed for a rebuild AOD with new torque converter and install with a 12 month warranty about $1000.
He has a 65 mustang that he works on himself.
that's a pretty good deal!
If strength is a concern, you can swap the guts of a 4R70W into an AOD so it won't need the computer. They are stronger. The biggest issue I have had with AOD's is the TV cable. If you don't get that set right you can burn up a trans pretty easily.
Re: Late model transmission question
+1 What Craig said, around here you'll pay around 800 just to get your AOD rebuilt and that's if you know someone.
Sent from my VS980 4G using Tapatalk
Glad to hear that I might have found a deal. I'm gonna try to get a few pics of his 65. He took his auto out and put a 5 speed manual in.
