I think the fuel ferries are stealing my gas. Between driving around town, idling in my driveway, and visiting with a few friends today, i went through an entire tank of gas. One of the things on my list to upgrade are the tank to the 22 gallon 70 unit.
Question are:
1. Is the stainless tank really worth th $200 and some change upgrade charge?
2. Is there anything needed electrically to swap out the sending units?
3. I assume the '70 sending unit uses the same gauge ohms as the '67. So my Autometer gauge should have no problems?
4. besides the things listed below, is there anything else i need to consider in order to have everything to complete the swap?
FUEL TANK KIT 22 GALLON W/ DRAIN PLUG
Fuel Tank Kit with Drain Plug, 22 Gallon for 1970 Mustang and Cougar.
Need to replace your fuel tank? Save money & buy the kit instead of purchasing all these item seperately. This fuel tank kit has everything you need to replace your fuel tank. Kit includes a 22 gallon fuel tank with drain plug, fuel sender with retainer, and a filler neck hose with the filler neck gasket.
FUEL TANK FILLER PIPE 70 MUSTANG
Fuel Tank Filler Pipe for 1970 Mustang.
The filler pipe attaches to the taillight panel by screws and runs down to the filler pipe hose which connects it to the fuel tank. The filler neck pipe is what the fuel filler cap installs onto. For the attaching screws, gasket, filler pipe hose and more, see Related Parts below.
This filler neck can be used with 1970 fuel tank #70002 to allow additional fuel capacity on 1965-1968 Mustangs.
Thanks!
Question are:
Thanks!
