I've been struggling on powertrain choice (351w or stroked variant vs Mod.)
I realize displacement is great, but with gas prices on the rise; I figured I can do some minor mods to the motor and get some decent HP and reasonable MPG from a mod motor.
Plus it seems like a fun challenge.
This is the same/similar as the '96 Cobra, Teksid Aluminum block. I think it may shave close to 70lbs??
I have a R&C MII crossmember with no engine mounts (well that's what I had till my body shop stole mine and made a home built version and welded it in place)
What trans is best for that motor and for a '67 fb (I don't mind cutting here and there to make a t56 fit if its best)?
My present dilema; Should I remove the home made crossmember and get the removable cross member from Rod and Custom or try out the TCI (total cost Involved)?
Neither claim to be true MII, both are MII type spindles. But they claim different/improved geometry. I hear the TCi drives better, but I can't figure what the differences actually are.
Part of my dilema is that I can get just the crossmember from RCmotorsports (about $400) which is easier on the wallet now. But TCI only sells the full monty; so when I add in the Wilwood rotors and caliper, it gets the price up to around $3200.... Timing is not good for that expense now as I am undergoing lots of bodywork.
I was thinking of getting cobra intake, assuming it will fit under an Eleanor or gt500 hood.
Any words of wisdom from the experts?
Thanks again
Thanks again
