Well my rebult 302 is smoking. I also find the compression is low, about 105 - 110. I squirted some oil in one of the cylinders and compression went to 127 so it looks like a ring issue. The engine was rebuilt before I got it and set for at least 2 years. I did spray the cylinders with WD40 before I put the heads on, but did not remove the pistons. My guess is the rings are stuck and/or the oil seals are bad. When I run the engine my oil pressure pegs the factory gauge. I should have pulled it down while I had it out, but there goes that hind sight being 20/20 again.
So what are my options? Is there anyting I can try before I pull the engine and tear it down?
Asside from high oil pressure and smoking the thing purrs. Of course it is being well lubricated.
Thanks
Thanks
