"daveSanborn" said:When does it rise?
Are you or have you replaced the original spring perches with roller units?
"daveSanborn" said:Dammit Mark.... wait for the symptoms before providing the cure.
I was thinking the exact same thing, but wanted to find out when he's seeing the rise. Stiff perches is the likely culprit.
"silverblueBP" said:Are you or have you replaced the original spring perches with roller units?
Should be -[glow=red,2,300].[/glow]5* camber."jpyoung" said:I gave the shop the following specs which I got from my good friends at Stangfix.
1/8 toe in
+2* caster (or more)
-5* camber
