So coming home from the last Cars and Coffee I noticed my speedometer bouncing like a ball. Time for some lubricant. Not my favorite thing to do because getting a hand behind the gauge and loosening and attaching the cable to the gauge is knuckle scraping. Also the screw attach points for the cluster are falling apart. Took my steering wheel off and another problem. Horn doesn't work (again).
Lubed the cable with some graphite spray and started the knuckle scraping trying to re-attach. Put the wheel back on....horn works (loose wire connection).
Now for a test drive to see if the speedo works.
