magnaflow exhaust kit
i had to have a stainless shop connect the hipo manifold to the x pipe. So while he was under there i had him tack all the pipes together, but i used the clamps to seal them.
NO WAY for me. The clamps are of very high quality and the beauty of them is one of the best parts of the kit. In fact unless you use anti seal on them they will probably seal all on their own if you wish to remove them later with ease. I plan to do some emergency brake work and sub frame connector work later, so easily removing the system makes work at home more manageable. I love the sound of this system. The only part that I had welded was the connection from the header back to the system as you do with all systems.
