toddwallace
Ok..I pulled the Demon and went with a Holley 650 with .25 carb spacer.. Car starts and runs about the same, but the problems personality has changed. Before, the car would die and not start (with strong smell of fuel) after 30 minutes or so... NOW, it runs fine and starts shutting off after 30 minutes, but it jump starts itself when you are driving and starts back up. When at a stop, the car will fire and immediately shut off. It does seem to get unusually hot in the engine compartment, but the temp gauge seems like it runs in a normal range. I truly believe, I have some electrical/fuel problem that gets aggravated by the hot engine compartment. I have hooked up a wide band and it is running real rich. below are my numbers..
Car at startup with 2 raps on the throttle
Car after 30 minutes of idling
Thoughts?
Thoughts?
