Midlife...I bought a tach yesterday to put on the Mustang. Small one that goes on the column.
I need to find a couple of good wires to splice into and since you reworked my underdash harness figured that make you da man.
Tach has four wires in question...two are easy / no brainer.
One needs to go to a wire that is hot when the ignition is in the on position.
Second needs to go to a wire that comes on when the dash lights are on.
The other two are easy....ones a ground and the other goes to the neg side of the coil.
Any suggestions on a good place to splice in on the first two wires?
Just looking for a place to splice in that will be the least interference?
