"Horseplay" said:Why aren't you out there figuring this out and fixing it? Thought you were someone who worked on their own car? That's the joy of old cars.
"Kats66Pny" said:The mini would be smaller and give more clearance away from my long, really hot, headers? Looking around, I see some mini's go anywhere from $150 up to $300. Ouch. I did come across some info about DB Electrical starters on VMF but seems kind of cheap for a mini starter compared to others out there and there's no core charge so seems a little fishy to me. :shrug Anyone here have a DB starter?
Something like this. It also has wiring included.
http://www.db-starter-alternator.com/p- ... d0001.aspx
"AzPete" said:Get a longer bar on the wrench to move the tension pulley for the belt removal....plus be sure you are going the correct direction with the pulley.
Is the battery dead? If not, jumping is not needed. If so, get it charging......
"Kats66Pny" said:Oh and more good news. Can't get the starter off. Headers are in the way and can't get to the one bolt. :rant
"Kats66Pny" said:Don't have a longer bar. lol
Battery is totally dead. Have no way to charge it.
"Grabber70Mach" said:Long extensions and swivels will go a long way helping you with this task.
You also need to charge your battery and have it tested. I've seen battery issues cause some of the starter issues you describe.
"Fast68back" said:Cat, look up rockauto, you can get one for under $100, a '95 5.0 starter shows to be $76.99 (plus $50 core, which you will get back)
