"Jonk67" said:Looks like good work but wouldn't they now have the ability to twist or move fore/aft under braking/acceleration? The range of motion is supposed to be up/down arc with no fore/aft movement. The only other items stopping them from moving are the strutrods? Are you installing adj. rod end strutrods?
Is the next step to box them or is that not necessary?
Not an engineer but that's the first thing that pops into my mind when I see that rod end ball/socket is different planes of movement.
Jon
"1109RWHP" said:I would also use some Seals It washers on the rod ends to keep the dirt out of the grease on the ball.
