Chris Kennedy
Hi:
I started this post several weeks ago and promised I would get back with some updates. First, here are the alignment specs:
1. Caster: 3.2 positive (L) 3.5 positive (R) (a bit less positive than I originally thought, but great for directional stability).
2. Camber: .8 positive (L) .9 postive (R)
3. Toe: .2 (L) and (R)
I checked the rotors, and they are fine, and all ball joints, tie rods, wheel bearings are fine, too. Car runs 225 60 15 tires on Torque Thrust Ds, all road force balanced, have rotated everything nevertheless, no change. There also appear to be no traditional bumpsteer issues, and I drive this car a lot in the real world (app 12K miles a year). I am also checking with Flaming River, a competitor of TCP, to see if this part of some larger issue with these R&P conversions in general. TCP really had nothing to suggest. The shimmy also seems to be influenced by road surface, although I have not seen a pattern as to which surface does what. One thing I am also checking with Flaming River about is their shock-absorbing u-joint. I am wondering whether part of the problem is simply harmonic vibrations in the system, itself, that don't result from any particular imbalances. Thoughts are welcome!
/s/ Chris Kennedy
/s/ Chris Kennedy
