A lot of my time this Spring has been dominated by these two..
1971 Airstream Sovereign 31ft (AS -- AirStream)
1975 F250 F-250 Crew Cab Short Bed 4x4 400/C6 (OFCC -- Old Ford Crew Cab)
I bought these both last year, the Airstream over the weekend of July 4th and the truck in late August.
The trailer was bought out of a hay field, mainly for the shell
But the previous owner had trashed the interior. He lived in it for 2 years, then one day he just left and moved out leaving all his 'stuff' in it. It was disgusting.
Interior Before
Looking rearward
From the rear looking forward
Basically anything that was not part of the airstream and was burnable, I burned, if it was metal, I recycled it at work, and it it was trash, I trashed it..
1 truck load of recycle
2.5 truck loads of garbage
2 truck loads of burnable
I have no idea how he fit that much 'stuff' into this trailer.
Fast forward to this last weekend (5/21 - 5/22) and the interior of the shell has been stripped of all walls, appliances, flooring, plumbing, and even some of the copper line for propane. We have primed the walls and started painting the interior and getting a feel for the new flooring.
The rearend where the bath room had been, also has a huge exterior hatch for access to the plumbing, the walls back there were filthy disgusting from road dirt. The clean swipe on the right was my first wipe of the wall, it took a lot more elbow grease
This was while I was priming the lower wall after the scrubbing.
The plan is to remodel the entire floor plan so that we (adults) get a master bedroom in the back, the bathroom is moved to the side (along with the black tank) and then we will probably use it for the remainder of this year while I do other piddly things like replacing all window seals and I'll hopefully start polishing the shell. If time or money allows, we will start refitting appliances, starting with hot water and a refrigerator.
Interior Before
Looking rearward
