My Candy Apple 68 turboed Fastback
Outrgus
New Member
I have owned this car for 19 plus years. Never completed, but close.
Engine:
331 ci
Dart SHP 4 bolt main block
Scat 4340 Forged Steel 3.250 Crankshaft
Scat 4340 Forged Steel H Beam Connecting Rods 5.400
Probe SRS 2618 Forged Pistons (14.2 inline) 4.030
Perfect Circle Moly File Fit Rings (TURBO)
Fel-Pro 1011-2 Head Gaskets
Clevite 77 H Main Bearings
Clevite 77 H Rod Bearings
Dart Coated Cam Bearings
Screw in oil Galley Plugs
ARP Main Studs, Head Studs, Oil pump Bolts
ARP Billet Oil Pump shaft
Moroso 8qt oil pan 20510
Moroso Oil Pump Pick Up 24500
Melling Oil Pump M68HV
Comp Cams Billet timing Chain Set
Comp Cams Hardened Pushrods
Comp Cams 1.6 Roller Rockers
Ford Motorsports F-303 Camshaft
Ford Motorsport Hydraulic Roller Lifters
AFR 205 Renegade heads
Weiand X-celerator Intake
Weiand High Flow Aluminium Water Pump
Power Master High Torque Mini Starter
Power Master 140 Amp Alternator
Tall Valve Covers -12 fitting to a catch can
Prothan Polyurethane Motor Mounts
Suspension & Brakes:
Front:
Flaming River 16:1 Steering Box, Quick Ratio
Global West Adjustable Strut Rods
Grab-a-trac 620lb 1 inch lowering spring
1 inch front Sway bar
Roller Spring Perches
Global west Eccentric Loc-out kit
Bilstein Shocks – Sport Valving
11 inch Disc (Ford Granada) with Braided Steel Brake Lines
One Piece Export Brace
REAR:
5 Leaf Mid Eye Springs 1 inch lowering
Polyurethane Eye bushing and Shackle Kit
11 Drum (57 Fairlane)
Low Profile CalTrac Bars
Rear End:
Ford 9 Inch 57.25 inches in length
Ford 3.25 Ring and Pinion
EATON True Trac Differential 31 Spline
Moser 31 Splined Axels
Induction:
C&S Blow thru Carburetor with Extreme Velocity Cab Hat
Custom Made Ceramic Coated Turbo System With Magnum Q-Trim T76 Turbo, Blow off valve, Catch Can, Methanol Injection and Waste gate
Fuel System:
Glens Performance Sleeper Fuel Tank, 22 Gal, 71-73 sending unit
Areomotive A100 fuel pump with 12304 100 Micro Fuel Filter
-8 Braided steel Fuel lines (Return system)
Mallory Boost Referenced Regulator.
Fuel Pressure Gauge 0-30 psi
Electronics:
MSD Digital Programmable 6AL-2 (6530)
MSD Billet Distributor (8598) with Bronze Gear
MSD Super Conductor Spark Plug Wires
Crane PS91 Hi Intensity coil
Transmission:
Ford Top loader Rug AW: Close Ratio
Hurst Competition Plus Shifter with “T” Handle
Centerforce SFI Steel Flywheel
Centerforce Dual Friction 11 inch Clutch and Pressure Plate
Wheels & Tires:
Front:
Wheel Replica FR500 18x8 (Narrowed one inch) 4.92 Backspacing
BFG g-Force T/A KDW 245/40/18
REAR:
Wheel Replica FR500 18x9, 5.92 Backspacing
BFG g-Force T/A KDW 275/40/18
Other Features:
Custom Hidden Front Speaker Enclosures, Sony Amp, Alpine AM/FM Cassette radio and Subwoofer
Drive Shaft Loop
AEM Wide band
Gauge pod with wide band and boost gauges
Autometer Sport Comp Tachometer
Front Seat Headrests
Battery Shut-off in Back-up light bezel with battery in trunk
Heavy Duty Radiator with catch can
Sub Frame Connectors
Hurst Line Lock
X/S Power Manual Dual Stage Boost Controller.
Last April in Vegas for the 50th.
Very nice. Appreciate the detail on your ride. 19 years is quite a love affair. It shows. Welcome to the Fix!
Thanks
I am very lucky my wife and kids enjoy the car also, makes it a bit easier to spend money on it, with out to much grief.
Here is what it looked like before it was boosted. With the original 14 inch ET rims.
289 with a 100 shot.
Nice rig you have !!!:cool::cool:
With all those parts , it wiil take me 30 years to do so.:eek:
And
Welcome to StangFix.:):)
note : I too have truetrac in the rear !! Did it make some noise the first 100 mls ??
Very nice looking fastback. That is the color I would like if I ever get to add a fastback to my stable.
No noise that i could here. Works like a charm, and now with the new tires i just picked up (285/35/18) Nitto 555r, should put it threw it paces.
Well the weather was nice today and i took the car for a little shake down run.
I'm am very happy with how it turned out, 10lb boost and blisters the tires in any gear. Time to get the new Nitto on.
