cool!"Dave2g" said:Doing the same!
Take a close look at the blade closest to the top of the radiator... I'm guessing it's some cardboard remnant that you put on the blade to protect the radiator during install... but it makes it look like the blade is bent over."tarafied1" said:huh :dun
I should probably add one but the fan is only a 1/2" away from the radiator"B67FSTB" said:Craig
Don't want to be a pain in the a$$ , but a fan shroud is a must IMO.
"tarafied1" said:I should probably add one but the fan is only a 1/2" away from the radiator"B67FSTB" said:Craig
I do not have overheating problems, or at least I didn't with the old radiator. I expect the new one will be even better."B67FSTB" said:If you don't have cooling problems in a hot climate , you can leave it that way , but I don't know better as with a shroud.
I believe then , when the engine is running , and you measure with a voltmeter between the housing of the rad and the min pole of the battery , zero volts . You don't have electrolyses in your system.
Or you measure , one lead in the coolant and the other lead at ground or min pole battery , the voltage which is an indication of electrolyses.
IMHO.
