need cam advice for late 302 block with alloy heads in 68 mustang
GT350
anyone recommend a good street performance cam for a late 302 roller block with edelbrock heads with pedastal mount rockers edelbrock intake,my trans will be a 5 speed t5 and a 3:55 rear full weight car so i need some good off the line grunt max will be 6500rpm
I've had good luck with the Comp Cams Xtreme Energy line, specifically the XE262. Good idle and vacuum but definitely better than stock.
"68EFIvert" said:
Trick Flow Stage 2
When I had my old engine built that was the other cam I was considering. I'll bet that TFS Stage 2 would've gotten me into the 12s more consisitently than the F303. But it probably would've broken a valve spring sooner than the F303 did. . . Make sure your valve train is up to the task!
Robert
Shoot Ed Curtis at Flowtech Inductions an email, he will be able to get you something better than anything that is off the shelf.
