need help in fitting 68 fastback trunk molding
GT350
need help in fitting 68 fastback trunk molding,the clips i got with them as crap as i see no way they could fit ,the only 2 end ones with the bolt/nut fit.
Any helpfull tips most welcome has anyone used double sided tape on this type of molding?
Did you have a close look at the clips ??
Maybe one side is for the hook up and the other side is for the slide. ( yeh bad explaination )
I had no problems with mine as it really clicks on.
Try to use some lube so it goes on easily.
